andyl – Member
I’ve narrowed the flooring down to three options-
1. Paint- cheap, quick but looks rubbish and low durability
Are you sure about that?
Grey PU floor paint will be very tough (the weakness is generally what it’s painted onto).
As used in commercial garages and industrial premises all over the world.
As used on the entire ground floor of where I work, all concrete, been recoated once in the eleven years I’ve been there, looking a little shabby in places, but considering the daily traffic of fork trucks and pallet trucks, shoving large heavy pallets around, and very large plastic tubs full of waste paper which weigh around half a ton or so, it’s not done too badly.
In a garage which is only going to get light foot traffic, I’d say it’s the best possible coating, plus, once its coated, you could get some old carpet and lay on top, to make it a bit warmer, and deaden noise a bit, even better get some carpet underlay, then put some old Lino on top of that, the foam underlay warms things a bit, and the lino is good for spills and being able to sweep up debris.
Sure you could do that on top of the bare concrete, but painting it will seal the concrete, help keep some damp out.
