so the old leaky revs got a service today.
got a £9 seal kit from evilbay and the oils etc and set about servicing it.
I’ve done loads of lower leg services/wiper seals etc so that part was fine, took the internals out following the sram guide, popped new seals in and reassembled.
cycled through the travel with no air in and all felt good.
inflated +ve chamber all good
put pump on -ve valve pressure was strangely the same as the +ve pressure id just put in..mmmmm cycled fork through travel at 100psi massive clunky feel and almost no resitance in stroke it went through all its travel to the crown with hardly any pressure on the fork…
took apart double checked everything.
re assembled and inflated +ve chamber, max of 125mm now on fork instead of 140mm and no change in any of the above problems…
any ideas? looking at the internals all laid out i fail to see where Ive gone wrong (apart from buying a £9 seal kit!!)
