FSA wheel help
[Closed] FSA wheel help
[#1118888]
Bought some FSA wheels new from a mate. The freehub is nice and tight and freewheels well. When fitted with a cassette and into the bike it is super stiff if i back pedal and the chain goes slack..
How do i get teh freehub off (sealed bearings) and what could be the cause? Tight bearings?
I am good with my pro2s but cannot see how to get the spacer off the free hub on the fsa wheels 🙁
i *think* they are xc 2 or 300s
Posted : 10/12/2009 6:00 pm
check the cassette isn't catching on the hub or spokes - some hubs need a small spacer 'tween cassette and spokes to stop them binding.
Posted : 10/12/2009 6:14 pm
not that - checked
Posted : 10/12/2009 6:35 pm
Do the hubs look anything like these?
[url= http://stickboycircusbike.blogspot.com/2007/12/snow-freehub-service-fsa-rd400-wheelset.html ]FSA hub overhaul[/url]
Posted : 10/12/2009 6:42 pm
no they are xc300s i think
Posted : 10/12/2009 6:43 pm
to get the free hub off you need to take out the opposite side bearings and then use a very LONG 11mm allen key to undo the free hub.(best way is to put the bendy bit of the allen key in a bench vice and cit the wheel on the long bit and the undo it like a big steering wheel, because the bugger are tight!) bearings seem to last quite well but the freehub is not a self service unit, i made a tool to get into the bugger and can now serice mine on a regular basis.
Posted : 10/12/2009 7:05 pm
You may also have difficulty getting hold of an 11mm allen key, nobody seems to list them, but a 7/16" AF turns out to be identical and available from any tool shop.Get a good one as they are usually well tight as mentioned above.
Posted : 10/12/2009 8:31 pm
got one cheers
Posted : 10/12/2009 8:32 pm
