Lovely hub this, eccentric axle means you can tension the chain in a normal frame (like the Kona I'm selling).
This is quite an expensive hub to buy £125 currently from Hubjub), nicely made with lovely smooth bearings and no play.
Recently built up into a silver 317 rim, hardly any use since, no wear to rim that I can feel.
Has a 17 tooth shimano freewheel and a 14 tool fix sprocket included.
I'm in Shrewsbury but travel up and down the M40, M5 via Bracknell, Hook and Bristol. E-mail in profile.
Tyre is included if you want it, e-mail in profile.
£70
