Spring clearout time...
2011 Slidey Inbred 29er frame, 18" in Orange, VGC. £135.
Reba Team forks, 197mm straight steerer, White, 20mm Maxle, Good condition, Couple of chips on lowers & some cable rub on crown, Stanchions perfect, Currently set at 120mm. £180.
Full Service/Seal kit for above, Inc fluids, (From TF Tuned). £25.
Remote lockout for above, newer machined type, £25.
Also have front wheel to suit above, Black Hope Pro2 on TN719 rim. Bearings as new. 20mm & Q/R adapters inc. £65.
Singular Swift rigid forks. Pretty much as new bar a few tiny marks. 197mm steerer. £40.
SLX 10spd 11-36 cassette. Hardly used. £22.
Deore HT2 Cranks, usual rubbing marks, No rings (See below), Inc fairly smooth BB, (Ok, one side is perfect, other not so perfect but has loads left in it). £25.
Surly SS ring, 32t, Stainless, hardly worn. £20.
2 x Thomson Stems. Std 25.4mm (Non O/S). Black. 50mm & 90mm. £25 ea.
Race Face carbon riser bars, 25.4mm (Non O/S), Width 640mm (IIRC), Good Condition, lacquer bit scratched but nice deep lacquer coat so dont think its an issue. £20.
Easton Carbon riser bars, 25.4mm (Non O/S), Width 670mm, VGC. £30.
Pics of most available if you drop me an email.
Cheers.
