I'm still in the process of clearing my flat out. These are some of the things I no longer need, I have pictures of everything (Please email me.)
Salsa Cromoto Fork (disc and canti) 425mm A-C, good condition, recently bought off here (steerer too short for my needs) 180mm x 1 1/8" Steerer. £50 Posted
Generic black rigid fork, V-brake only. 215mm x 1 1/8" Steerer. Good / reasonable condition. £15 posted.
Avid Juicy (5/7?) rear Brake, 140cm hose - Found a kink in the hose by the lever, would need to be shortened by 1cm or so, scruffy lever and calliper. £25 posted
Hayes El Camino front brake, 78 cm hose and IS adapter for 185mm rotor. Good condition - spare pads somewhere. £35 posted
Hayes El Camino rear brake, 125cm hose and IS adapter for 185mm rotor. Good condition - spare pads somewhere. £35 posted
Race Face Prodigy stem, in black-ish. 25.4 x 100mm (1 1/8" steerer) - A bit battered - £5 posted
(Road) FSA OS150 stem in black. 31.8 x 100mm (1 1/8" steerer) In good condition - £15 posted
American classic rear skewer. It does the job but is scruffy. £3 posted
Shimano XT (M750?) bottom swing, multi pull front mech. Good condition. £12 posted
Shimano XT 9 speed long cage rear mech. Used but in good condition. £15 posted
Look 337 road pedals, scuffed and scratched but work fine. No cleats. £10 posted
EBC disc adapter, Good condition. Believe its a rear to 203mm. I've not used it myself. £3 posted
EBC front and rear 203mm, 6 bolt discs. Good used condition, again, not used myself but appear good. £20 posted for the pair
Hope sawtooth Front and rear 183mm rotors. Used but with plenty of life in them still. £20 posted for the pair.
Race Face Deus XC OS 31.8mm clamp (low rise) bars. Generally good condition, some rubbing around the lever area. £20 posted
Nitto B123 track bars, 25.4mm clamp x 40 cm width, CroMo steel. Some scuffing on the shoulders but in good condition otherwise. Shiny shiny! £35 posted
FSA front disc wheel. Runs true, no dents but some scratching to the decals. Came from here but I like matching pairs. £25 posted
I'll accept offers, double up postage etc just need it all gone ASAP.
Will do a swap for a pair of rigid, disc forks (420mm a-c x 210mm steerer) if appropriate, also looking for a shimano nexus/alfine hub.
Thanks,
Chris
(email in profile)
