I'm selling my beloved Spec Stumpy FSR due to the arrival of a new one. '07 model with some upgrade(*):
FRAME FSR M5 manipulated alloy frame w/ Transform monocoque TT, sealed cartridge bearing pivots and rear shock mount, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 120mm travel
REAR SHOCK Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.75x1.75"
FORK Fox Float 120 RL, 120mm, rebound/compression adj, lock out, alloy steerer
HEADSET 1 1/8" Threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEM Specialized adjustable rise, OS 31.8, 3D forged w/CNC finish
HANDLEBARS Specialized XC low rise 31.8mm OS bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 620mm width
TAPE / GRIPS Specialized MTB, dual density
* FRONT BRAKE Avid Elixir CR, hydraulic disc, G2 Clean Sweep 185mm rotor
* REAR BRAKE Avid Elixir CR, hydraulic disc, G2 Clean Sweep 185mm rotor
FRONT DERAILLEUR Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
REAR DERAILLEUR SRAM X-9, 9-speed, long cage
SHIFT LEVERS SRAM X-7, aluminum trigger 9-speed
* CASSETTE / FREEWHEEL SRAM PG950
CHAIN SRAM PC-951 w /Power Link
* CRANKSET Shimano XT
PEDALS Shimano M-520 SPD
* RIMS DT XR420
* HUBS Hope Pro 2 front and rear
* FRONT TIRE Schwalbe Nobby Nic
* REAR TIRE Schwalbe Racing Ralph
SADDLE Specialized BG Rival, hollow Cro-Mo rails
SEAT POST 2014 butted alloy, black, 30.9 x 350/400mm
SEAT BINDER 7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
* A2Z Ti skewers
Brakes have done about 300 miles since I've installed them.
Price is £500 ONO.
I live in New Malden, SW London.
