OK, for sale here is a fantastic bike and the last year they made the M5 alloy frame with the anodized finished frame...its in black and has Rock Shox Sid race fork. You wont be dissapointed with its condition. You might find cheaper but i guarantee you wont find a better example unless its brand new in a shop!!! Its a 2009 model but was bought in Feb 2010 and the spec is listed on the Specialized website on the following link. I have the books/manuals and receipts too.
http://www.specialized.com/gb/gb/bc/SBCProduct.jsp?arc=2009&spid=40633
Its a 17 inch frame and the bike is in absolutely imamculate condition...its never i am ashamed to admit, even been off road unless you count cutting across the park on the grass!!! I would say its covered only about 500 miles onroad. I bought it intending to use it as a winter bike when it turned really nasty but ended up just spending these days using the turbo in the garage instead. It hasnt been ridden since last year (2010) as i'm a roadie i'm afraid.
Any questions then please feel free to ask and i am happy to send photos as required...sorry, i havnt worked out how to add them here. Mail me on stevemyers651@hotmail.com for pics or questions. Price is £970 and i am based in Kent. I wont post but would be happy to meet within a reasonable travelling distance if you are serious about buying. Someone mailed me and said its a lot of money for a secomd hand bike but i prefer to say its a lot of bike for the money!!!
I have also copied and pasted the spec from the Spesh site below:
FRAME M5 Manipulated Alloy hardtail, fully manipulated DT, TT, SS, CS, ST w/ shared tube Mono-stay seatstays, new larger diameter/stiffer ORE DT/TT, disc mount, replaceable derailleur hanger
FORK RockShox SID Race for SBC, 90mm travel, air spring, motion control damper, external rebound and floodgate compression adjj. w/ LO, alloy steerer
HEADSET 1-1/8" Threadless, 10mm insertion alloy cups, sealed cartridge bearing
STEM Specialized adjustable rise, 31.8mm clamp, 3D forged w/ CNC finish
HANDLEBARS Specialized XC flat 31.8mm, 2014 butted alloy, 6 degree backsweep, 600mm wide
GRIPS Specialized thin lock on grip (15.5/17") Specialized Thick lock on grip (all others)
FRONT BRAKE Custom Avid Elixir R Carbon SL, Carbon lever, SS hardware, alloy backed organic pads, 160mm rotor
REAR BRAKE Custom Avid Elixir R Carbon SL, alloy backed organic pads, carbon lever, SS hardware 13.515.5/17: 140mm other sizes: 160mm rotor
BRAKE LEVERS Custom Avid Elixir R Carbon SL Hydraulic, tool-less adj. reach
FRONT DERAILLEUR Shimano M660 SLX, 34.9mm, clamp top swing, dual pull
REAR DERAILLEUR SRAM X-0, 9-speed, mid cage
SHIFT LEVERS SRAM X-9, aluminum 9-speed trigger
CASSETTE Shimano HG61, 9-speed, 11-34t
CHAIN SRAM PC-971, 9-speed w/Power Link
CRANKSET Custom Shimano FC-M762 XT, 2pc., S: 170mm, others: 175mm
CHAINRINGS 22S x 32A x 44A, 4-bolt, 104/64mm
BOTTOM BRACKET Custom Shimano M762 XT
PEDALS Shimano M520, clipless
RIMS Custom DT Swiss X420SL, 24mm w/ eyelets, 28/32h
FRONT HUB Specialized Hi Lo disc, CNC flange, sealed cartridge bearing, Oversized end caps, 9mm DT RWS, alloy QR, 28h
REAR HUB Custom DT Swiss 370 w/ DT RWS QR, 32h
SPOKES DT Swiss Competition 1.8/1.6mm stainless, black, alloy nipples
FRONT TYRE S-Works Fast Trak LK, 26x2.0", 120 TPI, tubeless ready aramid bead, dual compound
REAR TYRE S-Works Fast Trak LK, 26x2.0", 120 TPI, tubeless ready aramid bead, dual compound
INNER TUBES Specialized Ultralight 26x2.0", presta
SADDLE Specialized Format, hollow Cr-Mo rails, SL foam, 130mm (15.5/17") 143mm (all others)
SEATPOST 2014 butted alloy, single-bolt setback, 30.9x350/400mm
