For sale is my Specialized Pitch Pro 2010 size MEDUIM with KSi900R 5" travel seatpost and DMR V12 platform pedals.
It comes with all paperwork, bits n pieces including; original post, spare brake pads and a spare derailleur hanger.
Bought new June 2010 and rides like new now. The bike has been well looked after with only the odd tiny paint smudge.
The bike was ridden for a few months 2010 but hardly ridden at all 2011 due to injury.
I can't speak too highly of this bike as a one bike 'do it all' solution, it's given zero problems.
FRAME DMD front derailleur mount, sealed cartridge bearing pivots, replaceable hanger, bolt on cable guides, 150mm travel
REAR SHOCK Fox RP2, 2 position shock with pro-pedal or full-open, rebound adj., 7.875x2.25"
FORK Rockshox Pike 351, 140mm travel, lockout and rebound adj, Maxle light thru-axle
STEM 3D forged alloy, 4-bolt, 31.8mm, 8 degree rise
HANDLEBARS Alloy mid rise bar, 31.8mm, 680mm wide, 9 degree back sweep, 6 degree up
BRAKES Custom Avid Elixir 4, full hydraulic, alloy backed organic pads, G2 Clean Sweep rotor, Front 203mm, Rear 185mm
FRONT DERAILLEUR Shimano M660 SLX, DMD, top swing, dual pull
REAR DERAILLEUR SRAM X-9, 9-speed, mid cage
SHIFT LEVERS SRAM X5 trigger
CASSETTE Shimano HG50, 9-speed, 11-34t
CRANKSET Truvativ GXP2 2.2, 2-piece crank set, AA rings, outboard bearing BB, S: 170mm, M/L: 175mm, Chain device
CHAINRINGS 36 x 24T
FRONT HUB Hi-Lo disc, 20mm thru-axle, 36h
REAR HUB Disc, double sealed cartridge bearing, high/low flange w/ OS contact side, 32h, QR
TYRES Specialized Eskar Control, 26x2.3", 60 TPI, tubeless ready, aramid bead
SADDLE Specialized Enduro BG, 7mm Cr-Mo rails
£1100
For full spec see http://www.specialized.com/gb/gb/bc/SBCProduct.jsp?arc=2010&sid=10Pitch
