4 bolt, 32T Shimano deoreish chainring (only just used): £12
5 bolt, 32T Truvativ ramped chainring (unused): £12
5 bolt, 22T Truvativ trushift chainring (unused): £6
110cm 1 1/8th Unbranded Alloy Stem: £10
130cm 1 1/8th Coda Alloy Stem: £10
DDG 20mm 36H Non-disc bolt through hub (unused): £15
Shimano SPD pedals (unused): £18
Avid A-D 1.0L V brake levers, quite scratched: £10
Random tektro v-brake lever: £Postage
Alloy cantilever brake bridges, one arm is a little bent: £5 pair
Grind pegs, 10cm, lightly used: £10
Pair of silver onza chill pills, only one bridge though: £10
Shimano LX parallel push v-brake, pads are nik nakked: £10
Diamond Assault T24: £100 ono
Its been sat in the shed for the last four years as I've not been able to bring myself to sell it. Well now needs must. Full 4130, 3 piece cranks, primo twister pedals. If someone is keen I could probably manage to arrange a courier, but I'm only 5 minutes down the road from chicksands.
Genuine Mitsubushi L200 Heavy Duty Seat Covers: £20
Again, they've been sat in the shed for years so need a wipe down.
Thanks for looking,
Damion.
