Re-list with some extras.
Hi all, sadly for me, but great for you, I have a fair amount of quality kit for sale as I have been informed by the missus, that we ‘need to move home’.
Rockshox Pike 454 U-Turn coil fork. 95-140mm travel, 20mm maxle and usual adjustments. Owned for around 14 months and they have only been out for about 400miles. Only a couple of small chips to the paint, otherwise they are perfect. 185mm, 1 1/8" steerer. No original packaging. £230 ono.
Hope ceramic bottom bearing. Spot-on gold cups, runs like silk having only been used for about 100 miles. £45.
XT M770 Rapid Fire front and rear shifters (3x9) come with XTR inner cables (£7 each alone). £45.
XT M770 front mech, dual pull top swing. 34.9 but have 31.8 shims currently installed (easy to remove if required) great condition with just a small amount of chain rub. No original packaging. £20.
XT M772 Shadow, long cage rear mech, again good condition with a small amount of chain rub and minor scuff to bottom of cage. No original packaging. £35.
Thomson Elite Seatpost - 27.2mm by 330mm, a little scuffed, only from lowering and raising seat height. No original packaging. £35.
SDG Bel Air Saddle - CroMo rails, no tears, a little grubby but still in good condition. No original packaging. £20.
Easton Vice DH Stem. 50mm, 10 degree rise. 25.4mm bar clamp. Slightly corroded clamp bolts. No original packaging. £12.
All items will be supplied in their original packaging unless stated otherwise. The price will include standard postage.
I have of course got photos for all the kit which I can email out on request.
