A beautifuly made frame, which is the same as this........
http://www.enigmabikes.com/bike/bike-enigma-elite.html
with a few small changes such as different dropouts, integrated headset.......
Made from range topping Columbus Spirit tubing, this frame is beautifully put together.
Dimensions are :
Seattube CTC 49cm, 51.5cm CTT
Toptube CTC 55cm (actual) 56cm (actual)
Headtube 14.5cm
Now, the fork is carbon with an alloy steerer - it's a winter fork and subsequently has loads of room for a mudguard.....the frame is very close clearance with a 700 x 23c tyre however, and there's no chance that you could ever fit a guard to the rear!
The frame has been touched up here and there - it's a good colour match though and overall the frame looks great, but it ain't pristine.
There are a few small dinks on the downtube caused through an incidence of poor transportation on a rack. This is cosmetic only and does not affect the frame's integrity......could easily be filled if you fancy a refinish by Colourtech (the original finshers of Omega frames and currently do the Enigma stuff I believe...)
So, the frame only new would cost £950, but you can have this one plus fork and headset for far less......
£220 plus postage......
11 speed Super Record UT chainset 172.5 53/39 ceramic bearings in immaculate condition with BS cups both boxed £235
Spinergy Spox wheelst in immaculate condition, having covered less than 450 miles. Clinchers for Campag 9/10/11.
£155
FOCUS Concept seatpost 31.6 350mm great condition £10
Challenge Criterium Open Tubular Tyre
same as these.......
http://www.planet-x-bikes.co.uk/i/q/TYCH
CRIT/challenge_criterium_open_tubular_tyre
Brand new unused £38 the pair
Carrati old shool wipe clean bartape in white NEW without end plugs £3 for 2 packs......
Lizard skins DSP tape in green NEW £14
Fulcrum Shimano pattern freehub in good nic. This came off a apir of Racing 7s that I changed to Campag. £18
Ritchey stem 130mm/std diam good nic but tarnished bolts £7
3TTT Forgie stem 130mm/STD dia bars excellent nic £8
SRAM/Truvatv Elita compact chainset 172.5 50/36 brand new GXP BB £45
Campag Veloce 9spd front mech good nic £10
Contact me at
lapit13 AT hotmail DOT com
Cheers!
