Used Ritchey Pro alu bar. Black with red and white logos.
Low rise, 670mm wide, 31.8 clamp size.
In good condition, coating (not anodising, dunno what it is) is abit worn, mainly from having grips, brake levers and gear shifters fitted. Also a bit worn around the stem clamp.
Most of the worn areas will be covered up once the bars are fitted to the bike, so you probably won't see much of it anyway.
Looking for £25 posted ono.
