Rockshox Reba 29er fork purchased in July 11 so just over 6 months old (invoice will be included). It started life as an RL model but before it was first used the Motion Control was swapped out for the Black Box unit from a 2010 Reba Team as it offers much better damping and the BBMC unit is titanium so lighter too! The air spring side was untouched and still holds air perfectly.
Fork has just had a lowers service and the stanchions are perfect as is the function of the rebound/damping; however the lowers are a little scarred. Due to a warped brake rotor the lower leg on the braking side has been gouged with the deepest part being about 1-1.5mm. This appears to be cosmetic and has not caused concern as there is a bit of material in that area.
Steerer is 196.5mm and no SFN is fitted as a Hope head doctor was used and this is the version with 20mm Maxel light. Fork will come boxed with travel spacers if required to reduce to 100mm or even 80mm.
Looking for £250 posted, email in profile.
