Hi folks, clearing out the shed to make room for another bike so lots for sale, willing to hear offers for multiple items as i really need rid of all this. Most stuff is used so has cosmetic damage but still all works fine.
Planet-x stem, 25.4mm, 120mm. £5
Oury grips, pink, some oil marks from being in spares box. £5
Acros headset, for 1.5" headtube, 1-1/8" steerer. £20
Salsa liplock seat clamp, 32mm, green anodised, new. £10
Salsa Fliplock seat clamp, black, used, £10
Unknown seatclamp, gray, 32mm. £5
Intense QR seatclamp, 35mm. £5
Maxxis Flyweight 490 - 1.95", fast rolling, used once, 490g, rrp£34.99!. £10
Maxxis Larsen Oriflamme - 2.0", FAST summer semi-slick, orange stripe, about 500g, was available in US only. £10
2 Kenda Short-tracker DH tyre, semi slick, i used (barely) other new. £10 each.
Manitou rear shock spring, 400lb, for 3" stroke. £10
Manitou Minute 29er forks, qr, 120mm travel (currently reduced to approx 90mm), air sprung, upgraded to new Absolute+ damper for improved control when descending. Think the steerer is 200mm, will confirm tho. £150.
Manitou Absolute damper (taken from forks above), good upgrade from TPC, £20.
Spot singlespeed wheel, 32h, Black, 6bolt disc mount, QR, Threaded for freewheel, Mavic X223 rim, no dings, no flat spots, some normal scuff marks etc.
£40
TA Chainring, 4 bolt, 42T, £10.
Pair of classic ringle bottle cages, silver, £15.
Surly Instigator frame, Large, Black. Burly hardtail that can still ride uphill. £70 (plus post)
Yeti ASR-SL frame, size Large, 2005 i think, Fox RP23 shock, hope headset, couple of spare hangers.
Could do with a shock service and needs a bearing kit but it was still riding well before i stripped it down last month. Usual cosmetic damage from cable rub ect. and some flaking of paint at seat-clamp and shock bolts. £300. Can include the F100's pictured for an extra £100 (not for sale separately)
DSC_0001 by dickyelsdon, on Flickr
Email me if your interested, i will check back here but can only usually get on at lunchtimes when at work.
Cheers,
Rich.
