Right lets start with the pictures:
Untitled by Jackass123456789, on Flickr
Answer Rove Stem / 50mm / 31.6 / Excellent Condition (like new) / £40 posted Answer Pro Taper Bar / Red + Black / cut to 720mm / low rise (not quite flat) / 31.8 / Some wear cosmetically to the anodizing, one patch where I used to hang my full face on push ups and some around the stem area / £25 postedCommencal Riser bar / 680mm / 31.8 / OK condition, not sure if I have ever used them / £12 postedEaston EA50 bars / 640mm / standard size / OK condition / £12 postedAtom Lab Dirt Jump bar and stem combo / funny size but match together / quite good condition / £25 posted (pair)Wellgo V12 copies / Grey / OK condition / £15 postedCrank Brothers Candy or Smarty (not sure) / Need a rebuild / £-Cost of postage and a beerWTB SPDs / Cleats included / hardly any use / £15 postedLOOK Easy Keo road pedals / used but life still in them / with fairly worn cleats / £15 postedXTR Cranks - Jeff Jones Style Single Speed ONLY - Middleburn 32T ring - 175mm arm length - Red bolts fitted aren't right and just used to hold ring and cranks together / OK condition, loads of life left in them / £70 postedFSA Gap cranks / 175mm length / BB included (lots of life left) / quite marked and scratched / £40 postedE13 G-Ring / 36T / Silver / 4 bolt / good condition / £18 postedFSA V-Drive Extreme ISIS cranks / 175mm length / OK condition / £20 postedSRAM SX 5 rear shifter and mech / 9 spd / OK Condition / £25 posted (pair)X-Tools HT II BB Tool / OK Condition / plastic end cap remover / £8 postedShimano Deore Front Mech / OK Condition / £10 postedSuperstar Ergo grips and mini bar ends / hardly any use / no end caps / £10 postedMarin Top Cap and bolt / £5 postedMarin Grips / red lock-ons / bear end caps / well used - good for lock-ons and end caps only / £5 postedSuperstar Excel Grips / Light blue / These are CHUNKY grips / Hardly any use / black lock-ons / plastic end caps / £5 postedHope Pro II 20mm adaptors / some marks on them but still work fine / £8 postedMRP boomerang / BB fitting / OK condition / £15 postedOffical Hayes 160mm disc / used but life left in it / £10 postedSome funny old spring / supposed to give a changing spring rate / fits OLD Van Rs / no idea on rates etc. / £ PostageBlack and Blue saddle / small tear on the side / £ Postage and a beerMoore and Wright Micrometer / Don't think it's ever been used / £12 postedTioga Front fender / I don't have any of the fitting but I used to tap a starnut into the bottom of my forks and attach that way - worked well / £15 postedNuke Proof Ti Spring / 550 x 2.25 / Like new / £75 postedRear black QR and 2 seat QRs (both 35) / £ PostageHalogen MR16 6v 5w bulb / think this used to fit some old Electron lights / £ Postage
Open to offers, bulk discount etc etc.
Email me at leeandrews@wc-freeriders.co.uk
