Used a few times, very lightweight KCNC crankset with external KCNC bottom bracket. No chainrings unless you want the worn Shimano ones that are on there, in which case I'll leave them on.
£100 + postage
£100 + postage
Very interested. Q's:
Standard Hope BB compatible?
Any special tools required to install?
Crank (only) weight?
Standard Shimano bolt pattern?
Crank arm length?
TIA
Standard Hope BB compatible = YES
Any special tools required to install? = NO
Crank (only) weight? 715g WITH KCNC BB and 44/32/22 KCNC rings
Standard Shimano bolt pattern? = YES fits Shimano etc
Crank arm length? = 175mm
You must log in to post.
