I've got two sets of brakes to sell.
Avid Juicy Carbon
These are in excellent condition, with plenty of life left on the pads. no noticeable marks on the carbon levers or main caliper bodies. Fitted with Goodridge Carbon Braided hoses.
Rear Hose Length: 132cm
Front Hose Length: 82cm
Will also chuck in a 114cm length of the same Goodridge carbon braided hose just in case you need a longer front hose for long travel forks - you can reuse Goodridge fittings, so you wont' need to buy anything else to change the hose.
Comes with a choice of Avid G2 rotors (c/w rotor bolts - torx head):
either:
160mm rear (with IS to Post adaptor)
185mm rear (with IS to Post adaptor)
and either:
203mm front (with post to post adaptor)
185mm front (with post to post adaptor)
160mm front (no adaptor - caliper is post mount)
Just let me know which discs and adaptors you would prefer. I would also be prepared to do a deal on all of these.
Looking for £100 ONO posted
Formula Oro K18
These brakes are in immaculate condition, with plenty of life left in the pads. Come with a Formula 185mm front disc (and post mount adaptor) and a Formula 160mm rear disc (with IS adaptor). I will also supply rotor bolts - torx head - for the rotors.
Front Hose Length: 84cm
Rear Hose Length: 130cm
I will also chuck in the following items:
3 x sets of SSC pads - brand new
Formula bleed kit which comprises two syringes fitted with the correct bleed attachments for the brakes
These brakes are immaculate, So I'm looking for £110 ONO posted.
