This is sitting around doing nothing, so would be better off put to use by someone! Looking for £150 posted.
Steel frame & fork bought from merlin cycles, measurements are:
Seat tube - 18 inch
Top tube - 22.5 inch
Standover of about 29 inches.
Shimano deore hubs on fir 232 rims, DMR single speed kit (16t), deore V-brakes, Continental sport contact 1.3 slicks, shimano tora road square taper crankset (53t ring) & generic bottom bracket (not in the best shape, but still spins) cane creek sealed bearing headset and giant stem and flat bars.
So to get it going you'd need, seatpost (30.0mm) and saddle, grips (I might have some I could throw in for a couple of quid) chain ring bolts, chain and single speed tensioner (and possibly some mtb cranks if you wanted a smaller ratio)
Pics can be found here: http://www.flickr.com/photos/pj266/
Theres a couple of minor dents on the top tube where the brake levers hit it and a few scratches around the place, its been used!
Would consider splitting too....
Many thanks, Paul
