Good condition.
Reluctant sale, . . but needs must at the moment . . .
They've had fairly light use in their 3 years, I don't generally ride in the winter months so that has helped the cause of the bearings - which still seem fine to me. There is minor damage to some of the stickers, but there aren't any major nicks, chunks or scratches on the rims anywhere, overall rims are good. From memory the rear wheel could do with slightly truing, but i've been riding it like it for a year, it's that minimal, you don't notice. The spokes are all straight and tight, some of them are loosing a little of their blackness, to be expected on a 3 year old wheelset.
One thing: the valves could do with replacing, I've been losing quite a bit of air through one of them, one of them is missing it's original collar which doesn't help and the other one doesn't quite screw down - they are £10 each on CRC. Other than that, when cleaned up they look very good, nice and light, but also very robust and good looking too. The front hub can be changed to be 20mm if you wish. I've been in touch with the distributor to try and find out if there is a kit that downsizes it to 15mm bolt thru, still unsure if such a thing exists aftermarket?
If you want images let me know.
They were about £300 when I purchased them, todays version is nearer £400!!
Great value at . . . . . £130 collected (west mids/shrops) postage at cost.
