Surly 1X1 26inch singlespeed wheels. Excellent condition. £100
On Mavic 521 rims. 32 hole. Disc only. Nice quality build.
Not QR but 10mm bolt-thru axles.
White Industries SS cranks. 175mm. Sq. taper. 34t chainring. £68
Some rubbing to arm. Can supply pictures.
Endura Humvee ¾ shorts beige. Size Medium (32). Good condition with the odd mark here or there. Perfect winter riding shorts £18.
Pearl Izumi short sleeve cycle jersey. Blue. Loose fitting. Rear pockets. Size Medium. £8
Altura short sleeve cycle jersey. silvery white. Loose fitting. No rear pockets. £5
Fox long sleeve jersey. Grey. Rear pockets. Size Medium. £10
Deuter 20L speedlite lightweight ruck sack. Hydration sleeve compatible. Trim around the zips a little worn but otherwise fine. £20
Pipedream steel rigid forks. 440-450mm axle-crown. 200mm steerer. Black. Straight blade. IS Mount only. £35
Spot Brand SS rear wheel. Disc only. Needs new cartridge bearings (about £5) with 16t shimano freewheel. £60
Mavic 317 front wheel on Cannondale hub. Disc only. 4 bolt. 160mm rotor supplied. £25
White Industries Duo freewheel 16t / 18t. Plenty of life left. £45
Onza tensile freewheel 18t lovely clicky action. Uses normal cassette removal tool. £25.
Would like to sell complete or have offers for bulk of parts before breaking my single speed for sale.
Sanderson Soloist single speed frame 16in. Very good condition. £140 or best offer considered.
Comes with spanners for EBB.
On-One carbon 440mm forks £60.
Middleburn singlespeed cranks and 32t singlespeed chainring. £70.
Avid BB7 brake calipers and levers. Pads good. Calipers good. £45
160mm rotors and mounts.
Raceface Evolve XC seatpost. 27.2mm. Black some insertion marks £11
