Surly 1X1 26inch singlespeed wheels. Excellent condition.
On Mavic 521 rims. 32 hole.
Not QR but 10mm bolt-thru axles.
Use XCR suspension Seatpost. Hard elastomer fitted. £25
Middleburn Chainset. Black. Square taper. 175mm arms. 5 bolt spider. £55
Rubbing to arms but tapers good.
Outer chainring useable but will need replacing shortly.
Middle and inner are fine.
Inner granny chainring has a bolt sheared but working fine on the remaining 4.
Crank Bros Candy C pedals. Blue. New and Unused. Came on a new bike With cleats ~ I think. £18.
White Industries SS cranks. 175mm. Sq. taper. 34t chainring. £80
Endura Humvee ¾ shorts beige. Size Medium (32). Good condition with the odd mark here or there. Perfect winter riding shorts £18.
Altura ¾ riding shorts. Size Medium (32). Convert into full-length riding trousers with zip-on legs. Discoloration on seat area but OK condition with no holes or tears. £12
Rohloff singlespeed chain tensioner. £28
Hope 90mm stem. 25.4mm fit. Black. Good condition other than a bit of discoloration of the bolts. Otherwise pretty much unmarked. £25
X-Lite carbon riser handlebars. 25.4mm fitting. Light and strong. Excellent condition £27
retro(ish) Pace stem. 110mm. Lovely condition. £20
A nice set of Titanium flat handlebars. Pretty much new. Brushed finish. £28
Magura Louise / Julie HP brakes. Hardly used. Newish Louise levers with Julie HP calipers.
New levers (having stripped thread on old one). Will require new hose and bleed on back.
Pads have plenty of life but will sell on with a couple of new sets of pads.
Maguara 180 / 160 rotors. £45
Various Avid BB5 calipers. Some with pads. Some without
Various Avid BB7 caliper. Some with pads. Some without.
Various Avid brakes levers for the above. Enquire and I’ll endeavour to sort out a proper description.
Kinesis alloy rigid forks 440mm axle-crown £25
RS Revelations, adjustable travel 80-130mm very very light surface mark on stanchion. But run fine. £85
Planet-x Kaffenback. Size Small. Pale brown in colour. Used but in good condition. £65
Kinesis Cross light forks £35
Tektro 520 Canti brakes £15
Surly canti-hanger for seatclamp £8
