Fox DHX Air 4.0
200x50
Adjustable propedal. Compression damping can be adjusted from very light to very firm by changing the pressure in the boost valve. Rebound can be adjusted with the red dial at the top.
Shock is in good condition, has only about 100 hours usage and had the air sleeve service done (incl. seals changed). Only used for about 10 hours since. I've owned it from new. I think the bushings should still be okay, but I'm not guaranteeing this.
£100 posted.
