Bought off here a while ago but I need more steerer!
2007 Van Rs with 2008 lowers (the versions with the two QR mounts) that were replaced under warranty. Brake fitting is therefore postmount.
Barely a mark on the lowers, stanchions perfect, oils topped up as well.
Come with two springs.
One thing to mention is that some of the edges of the preload bolt are a bit chewed but it opens no problem. The preload itself is tight and some lube!
£300 posted or less if collected from Sheffield or Derby.
Pics on request.
