FOR SALEEE
new parts off a 2012 orange five pro
ans some used stuff out the shed
New Orange Supercross Plus Bar £20 posted
This riser bar aimed at all round use, offers the higher position without the weight penalty of downhill bars. Features wide-bulge profile to add strength, however, it is not recommended for heavy downhill use. 6061 double-butted heat-treated aluminium. 30mm rise, 9° sweep. 680mm wide. 31.8mm clamp diameter. Weight: 300 grams
NEW Orange Stalk Stem £15 posted
Lightweight, ergonomic stem design with four-bolt security on 31.8mm ∅ bar clamp. The perfect way to connect your bars. CNC machined, 7°rise, 70mm reach. Black
NEW RACEFACE RIDE XC SEATPOST £20 posted
Race face ride seat post 30.9 mm
SPECS:
BUILT FOR: XC
LENGTH: 350mm
WEIGHT: 295g (27.2mm)
COLOUR: Bad Ass Black
loads of pics here pics here
[b] used stuff
Easton EA70 Monkeybar 685 Riser Bar £30 posted
very good condition
Used approx 60hrs
Finish - Black Ano
Bar Weight - 265gr approx
Degree Bend - 9deg bend, 5deg upsweep
Bar Width - 685mm
Clamp Diameter - 31.8
Material - EA70 aluminum
Rise –High
NUKEPROOF RISER BAR RRP £25 Posted
Manufactured from high grade 7075 aluminium and featuring a shot-peened finish to maximise fatigue resistance, all Warhead bars feature a 31.8mm diameter clamping area for stiffness and strength at a remarkably light weight (just 298g for 760mm flat bar version).
PLEASE NOTE CUT TO 600MM
NUKEPROOF STEM £25 pOSTED
110mm(note change ) WITH A BIT OF RISE sorry its not marked ?
Slx shifter 9 spd very good condition £35 Posted
Questions email in profile thanks DTD
