Endura MT500 overshoes size large (43-44 according to them, which is about right, but I'd err smaller). Still got plenty of life left, barely any loose stitching and the soles are relatively intact too. They've not had much use as I switched over to waterproof boots last winter. £25 RRP - yours posted for £12.
FSA PowerPro cranks NOS, triple, 94BCD, 5 bolt, 175mm arms, square taper. These were bought for a project that's now changed tack. Of note, and not mentioned when I bought them, is that there's a colour difference in the anodising. One arm is lighter than the other. In reality, once fitted, you're not really going to spot it, but I think it's important to know! They're new old stock, unfitted with only a few marks on them from storage, I guess. I have a 42T chainring that fits if you're interested (see below). Will build up as a triple or a singlespeed if that's your bag. £20 posted ono.
Also have a square taper BB if you need it.
ODI / Troy Lee Designs lockon grips - just the rubber part - no collars, but they obviously fit standard ODI collars. Some wear starting to show, but well worthy of a winter bike. Nice asymmetric pattern and thumb flange… £8 posted
42T chainring. 5 bolt. 94BCD. Brand new - fitted, never used. Has some sort of deliberate shaping of certain teeth - they're not damaged! Fits the FSA cranks (above) £12 posted.
Clarks universal brake kit - white, brand new in box. Suitable for all brakes bar STI levers - outer and two inner cables included. £9 at CRC (but out of stock). £7 posted.
Genesis 110mm flip/flop stem. Oversize steerer and standard size bar clamp. In good condition with a tiny bit of surface rust to the bolt heads. £9 posted
Post Moderne Cushy ST suspension seatpost. 25.8mm x 350mm. Hardly used and in practically 'as new' nick. Adjustable preload, 40mm travel and fitted with the silver, medium spring. £12 posted.
PP gift or bank transfer please. Everything posted promptly, 2nd class or parcels. Do drop me an email if you've got any questions - open to sensible offers too. Just shout if you need any more pics. Cheers.
