One unloved but totally sound Cromo Caldera Frame with P2 forks, Kona bars and Kona Stem.
Frame is v-brake only, forks are disk only. I ran the frame with an avid BB7 disk brake which I'm happy to sell with the frame if it all goes as a complete set.
This is a lovely ride, even though it was too small for me (5'11), would probably be best for someone 5'8 to 5'10.
Loads of lenght in the fork steerer if someone wants to cut it down.
Headset is an FSA Orbit XLII, bearings are a bit gritty but in my experience (I use them on all my bikes) removing the seals and cleaning/regreasing normally sees them right again for a few months, plus spares are easy to find anyway.
I'll include the bottom bracket if you want it, a sqr taper UN54, and a set of cranks with a 32 tooth chain ring to fit. These were removed to check they could be and the plastic bit of the bb lost a few teeth, this should probably be replaced but the bb bearings themselves run nice an smooth still (why fix something that aint broke eh... oh).
Lots of chips in the laquer, lots of scratches, few bit of heel rub bare metal showing but no damage to the frame, nothing but a little surface rust and I mean a little, the BB area is completely solid.
Also has a seat clamp, seat post is 27.0 mm.
So, I'd like £100 for this little lot, £120 if you want the brakes (front bb7, rear avid v-brake, and levers).
I'm also selling a rear wheel that suits this, see my other ad.
Cheers.
I'm in Shrewsbury but travel up and down the M40, M5 to and from Bracknell, Hook, Bristol quite a bit. Would rather meet up but will post if we split the actually cost.
E-mail in profile.
