Bought recently with a frame and not really suited for my riding
Excellent condition with very little to no use by the looks of things, works perfectly drops and returns fine with no play within the shaft/post
31.6 fitting, has a cosmetic scratch from fitting which extends 20mm above the "minimum insert" level, so would probably vanish the miniute you put it in a frame
No marks to seal or shaft
Currrently £110 on CRC, £75 posted please
