For sale:
EA70 Risers. High Rise. 660mm. Used and usual marks from brakes and stem. No gouges, dents or bends.
£20 posted
Easton EA50 stem, 90mm x10degrees rise. Good condition with slight cosmetic marks. Stem Faceplate bears a gouge near the top bolt hole – just visible on the bars picture above.
£10 posted
Crank Bros. Power Pump
I've gone CO2 for minimalist tyre inflation these days. Works Fine. £11posted
M-part Torx head stainless steel rotor bolt pack.
Never used and unopened £3posted
Gusset Singlespeed Conversion Kit
Never used (except briefly, the lock ring) 16t and 18t sprockets. £10 posted
XT Front Mech. M751. Top pull
Sat in a box for the last three years after only a little use. Pivots all sound. £15posted
Salsa Rear Q/R. Silver
The observant amongst you will notice is customised with a Hope brass cam socket for extra life. £9 posted
Steel Granny Rings. 9spd
Bought as spares and never used.£6 each, posted
32T Steel Middle ring. 9spd
Bought as spare and never used. £9 posted
Hope Rear q/r Axle -135mm and q/r rear hub spacers
Cosmetic bearing mark in one place. Axle £9 posted, Spacers £7 posted. Together, £15posted
Topeak 'Survival Gear Box'
No longer used. All tools present. £12 posted
SRAM X.7 oldstyle RH shifter
lurking in a box since I upgraded to the new style ones. Works fine. Some scratches to indicator window. £10 posted
SRAM X.7 Mech.
Good Condition. £20posted
LG Flatron 1730s 4:3 LCD monitor. No dead pixels, no screen damage. D-sub input only.
£50posted
