Fox DHX 5 Air shock (2009 model) 8.75" x 2.5"
£140
Excellent condition with Propedal, Bottom out damping and rebound adjust. No fixing hardware. Can come attached to a Iron Horse 6 Point Large/19" (2009). Well used for a year or so, then semi-retired. It has raced the Mega a couple of times, some SDA races and done a few uplifts, including Moelfre. It has got loads of paint chips and scratches. All bearings replaced last year and headset bearings also replaced with Hope bearings. DW link, ISCG05 mount, 150x12mm rear, 83mm BB shell. £300 if bought with the air shock, £350 if bought with the coil.
Fox Van R (PUSH tuned)
222 x 63mm, 350 x 2.8 steel spring. £120.
Thomson Elite seatpost 30.0x330
£35
Shimano Saint FD-M817 Front Derailleur
£15
Pair Shimano Saint M-810 shifters
£65
Shimano Saint Shadow Top Normal Rear Derailleur (medium cage)
£45
Shimano Saint Chainset Double M815 cranks
Pretty scuffed and scratched (esp on left arm), but chainrings in good nick. 83mm only No bottom bracket.
£100
MRP LRP Shiftable Dual-Ring Guide with unused bagged Dinner Plate bash guard
Rolls fine, but bearings could be replaced. ISCG05 £20
Sunline V1 Flat Bar Black 762mm Wide
Erm, not much to say apart from that they are wide....and flat. £35
DT Swiss FR440 Rear hub (150 x 12mm) 32h
The hub and freehub run perfectly. Currently built onto a Stans Flow rim with silver DT Comp 2/1.8mm spokes HOWEVER the rim has a few dings in it and is probably beyond running tubeless. It can still be used with a tube no problem though, but due to the dings is pretty hard to true and evenly tension.
So, if you like, you can have the rim for free if you buy the hub, or if you are not fussed about the rim, I'll strip it down and just post that.
£200
I've got a few more pics of the frame and forks, but am more than happy to answer any more questions about the kit on here or by email. I'll add a few ££ on for postage depending on what the item is, and am based around Bolton, if you are thinking of trying to collect stuff. I hope I've been (more than) honest about the stuff!
