I'm very proud of my bike parts collection, but it is probably of more use to other people than me.
All this needs to go in the next few days. prices are included to fit with forum rules, but please make an offer on anything. all include postage too.
all photos can be found Here
one green and one blue Spring for FOX VANILLA forks, from a 140mm 2007 model, may work with others £10 each
XT rapid rise long cage mech £10
203mm Hope saw tooth floating rotor in blue (some adonising worn off due to rubbing against fork) £15
still packaged 180mm hope floating rotor in blue, BRAND NEW £20
2 x Hutchinson Spider tubeless tyres. one bead has frayed slightly, but last time I tried they mounted with sealent no problem. £15 pair
2003 Magura Louise front brake. may need to be bled, and pads are pretty low on wear. no rotor £20
and Magura louise (2002-2003) or clara (2001) pads £5
Cannondale riser bar 25.4 clamp, about 630mm wide, reasonably light £5
2 unbranded rear skewers and one front skewer. all work fine £1 each
ISIS FSA V-drive crankset (22,32,44) with FSA bb. teeth have life left, as does bottom bracket. £10
Square taper LX crankset (22,32,44) very scruffy but rings will do another few months £10 or £15 with square taper (68mmx110mm) shimano BB
Kona mech hanger. maybe for a 2000ish cinder cone, but not entirely sure. £cost of postage
Tekro V-brake levers £cost of postage
front STX-RC V-brake lever £5
front avid SD V-brake lever £5
rear Shimano alivio lever and brake arms £cost of postage
STX-RC V-brake arms or Avid V-brake amrs £5 each
Size 46 shimano shoes, no cleats. £5
Airwalk snowboard boots size 44, good condition £40
Deore cassette 11-34t, hardly used. £10
200mm x 27.2mm Race face seat post £5
330mm x 27.2mm cannondale competition post £5
random assortment of 110-120mm stems, all 25.4, all free plus postage
same goes for random assortment of bars, all flat, all free plus postage
and if you're still reading... you deserve a pint!
