Clear out of some old and new bits including a kayak(!) to fund a cx bike.
Rear road wheel. Un-named hub on open pro rim. Bearings reasonable but needs a service. £25 collection only
http://www.facebook.com/photo.php?fbid=872582261603&set=a.872582211703.2469113.61207796&type=1
Front road wheel . Un named hub Alex rims AT450. £20 collection only (both for £40)
http://www.facebook.com/photo.php?fbid=872582316493&set=a.872582211703.2469113.61207796&type=1&pid=46494602&id=61207796
Topeak Master Mini DX. £12 brand new posted
http://www.facebook.com/photo.php?fbid=872582351423&set=a.872582211703.2469113.61207796&type=1&pid=46494604&id=61207796
On-one mary bars (funny shaped things) £10 posted
http://www.facebook.com/photo.php?fbid=872582371383&set=a.872582211703.2469113.61207796&type=1&pid=46494606&id=61207796
Specialised oversize xc bars (645mm). Chipped paint but should be hidden by grips and controls. £10 posted
http://www.facebook.com/photo.php?fbid=872582436253&set=a.872582211703.2469113.61207796&type=1&pid=46494609&id=61207796
Be-one blizzard saddle. V. light bit narrow for me. £10 posted
http://www.facebook.com/photo.php?fbid=872582456213&set=a.872582211703.2469113.61207796&type=1&pid=46494610&id=61207796
Aluminium bottle cages £5 pair posted
http://www.facebook.com/photo.php?fbid=872582476173&set=a.872582211703.2469113.61207796&type=1&pid=46494612&id=61207796
Shimano sora shifters. Triple and 8spd £20 posted
http://www.facebook.com/photo.php?fbid=872582620883&set=a.872582211703.2469113.61207796&type=1&pid=46494622&id=61207796
Deore 556 hydraulic brake lever. Knackered but suitable for spares or hack £7 posted
http://www.facebook.com/photo.php?fbid=872582675773&set=a.872582211703.2469113.61207796&type=1&pid=46494623&id=61207796
Bontrager saddle - too heavy for my road bikes £10 posted
http://www.facebook.com/photo.php?fbid=872582705713&set=a.872582211703.2469113.61207796&type=1&pid=46494624&id=61207796
Specialized seatpost 30.9mm diameter 350mm length £12 posted
http://www.facebook.com/photo.php?fbid=872582755613&set=a.872582211703.2469113.61207796&type=1&pid=46494627&id=61207796
Deore 9sp shifter £6 posted
http://www.facebook.com/photo.php?fbid=872582785553&set=a.872582211703.2469113.61207796&type=1&pid=46494629&id=61207796
Bontrager road stem. 17deg rise at guess ~100mm. for road bars so 26mm clamp. Might work on a hack mtb but I wouldn't run it on a proper mtb £10 posted
http://www.facebook.com/photo.php?fbid=872582820483&set=a.872582211703.2469113.61207796&type=1&pid=46494632&id=61207796
Concept SL seatpost 350mm 31.6mm £15 posted
http://www.facebook.com/photo.php?fbid=872582935253&set=a.872582211703.2469113.61207796&type=1&pid=46494637&id=61207796
Concept SL road stem for oversize bars. Will work with oversize Mtb bars but not for heavy duty riding. 110mm. £17 posted
http://www.facebook.com/photo.php?fbid=872582965193&set=a.872582211703.2469113.61207796&type=1&pid=46494640&id=61207796
Deore front mech £5
http://www.facebook.com/photo.php?fbid=872583015093&set=a.872582211703.2469113.61207796&type=1&pid=46494643&id=61207796
FSA stem. 100mm for standard 25.4mm bars Mtb £5 posted
LX shifters. Pair £20 posted
http://www.facebook.com/photo.php?fbid=872583064993&set=a.872582211703.2469113.61207796&type=1&pid=46494647&id=61207796
20" shraeder tube. Removable valve core £2 (not worth posting unless you are buying something else)
http://www.facebook.com/photo.php?fbid=872583114893&set=a.872582211703.2469113.61207796&type=1&pid=46494650&id=61207796
Planet-x downhill bars. Wide, high rise. Standard diameter. Uses a shim which is wierd but works fine. Heavy and strong as a scaffolding. £10 posted
http://www.facebook.com/photo.php?fbid=872583139843&set=a.872582211703.2469113.61207796&type=1&pid=46494651&id=61207796
Tiagra 9spd mech £6 posted- suitable for hack
http://www.facebook.com/photo.php?fbid=872583194733&set=a.872582211703.2469113.61207796&type=1&pid=46494654&id=61207796
Bontrager sq taper crank set road sized rings. Triple. £13 posted
http://www.facebook.com/photo.php?fbid=872583284553&set=a.872582211703.2469113.61207796&type=1&pid=46494659&id=61207796
Trek 1000 aluminium road frame and carbon forks (alu. steerer). 27.2mm clamp standard external headset. Rack and mudguard mounts (including fork) making it ideal as a winter road bike or commuter.
£50 collection only.
Kayak - Perception Blaze 7.1, yellow and orange. Several years old but not used anywhere near enough so £250 - must be collected.
I am prepared to negotiate if you are able to collect where the price is for the item posted. If you want more than one item then we can discuss the price. All items in Newcastle Upon Tyne.
If you want anything or some more info then email bayley.jon@gmail.com
