All prices posted – click the photos for larger pics...
Had this stuff a while, some of it not used for ages, need to get rid now!
CASSETTES
Shimano LX 9speed, older but hardly used, £6.
Shimano XT 9speed, £6
SRAM PG970, £6.
SRAM PC971 CHAIN
Part-worn but worked ok with the LX chainset & XT cassette, £5.50
CHAINSET & BOTTOM BRACKET
Deore LX octalink, rings a bit worn but worked ok with the xt cassette & chain. BB seems fine. £15?
FRONT SHIFTER
Deore rapidfire, shifts & clicks well but indicator doesn’t move. Repair possible? £7.
FRONT MECHS
Deore 34.9mm multi-pull + XT 28.6mm bottom pull, good condition & work well, £8 ea.
31.8mm adaptor available too.
REAR MECHS
Deore LX, minor scuffs but worked well, £7.50 each.
V BRAKES
Deore LX including noodle, £5.
Cannondale CODA with part-worn pads. Good condition, lightweight, stiff & work well, £12 the lot.
LIZARD SKINS FRAME PROTECTORS
Chainstay one is grubby but works ok, £2 for both.
STEMS, surplus to requirements, £5 each.
Profile Boa, Mid-length high-rise.
Raceface, 110mm i think, 5deg. rise.
QUICK RELEASES £1 each/£1.50 both?
OFF TOPIC
CAR RADIOS, Peugeot 106 (£7.50) & Ford Focus (£12.50), worked ok & both with cd-control.
