(1) Bought recently off here with the intention of fitting this to my Transition (which is now sold) - so I no longer have any use for the shock.
Cane Creek Double Barrel in good condition and full working order.
190x50mm
Its set up for an Intense I believe, but can be tuned easily for any bike that takes a 190mm shock - I emailed Cane Creek in USA and had a return email with full settings for my Transition - just never got round to setting it up. Basically its a simple as winding the adjusters off and then adding turns to what Cane Creek suggest. (4 adjustments in total)
Fitted with a 550lbs spring (steel)
Fitted with Transition bushes.
£260 posted
(2) Just sold my FS frame with the intention of building a hardtail. My Fox forks are a bit too much travel so thus putting them up for sale to free up funds to buy a replacement.
2008/09 Fox 36 Vanilla R forks
In great condition, work perfectly and have hardly been used. They have been on my second bike so haven't really seen much use at all - stanctions perfect (I serviced them last year and they were pristine inside since they have been used 4 or 5 times since in the dry), lowers in VGC too.
160mm travel
1 & 1/8" steerer which I think is 200mm long (will need to double check)
Medium spring fitted.
20mm Axle
£300 posted
(3) Nukeproof Warhead Seatpost - 31.6 / Black - Used twice so pretty much 'as new' - £30 posted
