DSCF2159 by kimberley robinson, on Flickr
DSCF2160 by kimberley robinson, on Flickr
DSCF2163 by kimberley robinson, on Flickr
DSCF2165 by kimberley robinson, on Flickr
I bought this in standard trim of a few months back, spent a few hundred quid tinkering with it and have never used it. Unfortunatley its 4th in line on the merit list.
Its a 2010 model in 19", comes ugraded from stsndard with Rockshox Revelation Dual air forks, currently set at 120mm but can be adjusted internally with spacers up to 150mm. Hope reducer headset to take up the slack as the frame sports a 1.5" headtube. Easton bars and truvativ team stem. Also running mavic crossride wheels with a maxxis combo of crossmark rear and advantage front.
everything else is standard as it came out of the box, which includes a transmission made up of XT, SLX and Deore. Braes are solid shimano units.
Overall in mint condition, one or two small marks from use. It is in perfect condition nuts and bolts wise and needs nothing. The brakes dont need to be bled, it doesnt need pads, the transmission is precise and nothing is worn. The tyres are only month old as are the wheels. The fork is smooth, controlled, holds air and all the external adjustments work as the should. It rides like a new bike because its hardly been used. In 2010 it retailed for just under a Grand.(With a far lesser spec than it has now)
Looking for £550 collected (northumberland) or posted at cost.
Email please
leerobinson598@btinternet.com
Thanks
