Cannondale Judge FR1 2006/7
Medium size
Fox dhx 5 with 400lbs steel spring
83mm b/b shell with iscg '05 mounts
Thru 12 fit 150mm rear hub fit only
27.2mm seatpost size-full length seat tube
1.5" Headtube- supplied with 1.5"-1 1/8th" reducer headset with cartridge bearings-all mint
Frame spec for medium size as follows:
Seat tube size: 27.2mm
Top tube horizontal: 23.4"
Top tube actual: 21.2"
Head tube angle: 64 degrees
Seat tube angle: 69 degrees
Standover: 30.8"
Wheelbase: 45.8"
Front center distance: 27.9"
Bottom bracket height: 14.7"
Bottombracket drop: 1.7"
Chainstay length: 18"
Head tube height: 23.2
Fork rake: 1.8"
Fork trail : 4.4"
Rear travel: 220mm/8.7"
Shock eye-to-eye: 9.5"
Shock stroke: 3"
Recommended sag: 30%
( All dimensions are given with suspension fully extended position using a 66cm/26" tyre diameter.
Bike not heavily used at all and so is in very good condition, there are a few marks/ chips but on the whole is in very good shape.
The swingarm has been fitted with an upgrade kit for the shock linkage supplied by cannondale to help reduce the wear on the moving parts.
I have spares for the linkage too such as the axle and cartridge bearings for the top tube swing link, spare y-links are supplied too.
Owned by a mechanic who has access to all of the required tools so nothing has ever been bodged on this frame.
The headset cartridges are also brand new so again perfect condition.
Bike was around 41.5lbs when stock new but with my own parts it was a fraction over 39lbs, it could be built lighter though.
It's a solid bike more than capable of racing, its also a rare bike too making it stand out a little but still quite subtle.
There is also a brake link available from cannondale, this helps isolate the braking forces and makes the bike squat a little in the corners, I've heard good things about it but its rides perfectly well without it.
The frame also comes with the full FSA headset as well as 2*spare cartridges for it.
Also there are 2*spare rear shock bushings with the spares that come with the rest of the spares.
last but not least, there is also the cannondale judge swingarm/bushing tool kit, this also comes with a bushing press for the shock-this on its own sells for £50.
I don't really ride my bikes much anymore and also can't really afford to build a whole bike, its also too nice to let it go to waste and that's why im selling.
looking for £550-OFFERS WILL BE CONSIDERED
