For sale my panasonic bullet camera, Ive used the velcro mount and as such it still has the velcro stuck on it, in order to attach it to you helmet you will need to buy some more sticky velcro.
Your need a recording device, something like a camcorder or DVR with a video input, the connections are RCA (phono) but you can convert these down to mini jack if you get the right adapters.
It works with PAL 625 Standards
The camera is capable of capturing a max 752x582 resolution, or 720x576 for most recording devices (SD).
0.3Lux at F2.0
Video output is 1.0v composite video.
The microphone is broken, as you can see its missing the microphone, ill include this.
These can be bought for £12.50 from here:
http://www.rfconcepts.co.uk/helmet_cam_accessories.htm
These videos have been recorded using a MiniDV video camera. Saved as AVI files on the computer and then edited and encoded into low bit rate Mpeg4. The original quality is much higher but obviously uses up alot of memory.
www.vimeo.com/5638460
www.vimeo.com/5637745
£35 Delivered
Any questions just ask.
email: Russalford@gmail.com
