Hello.
I have just gone through my garage and cleared out all my unwanted bits & bobs, so here they are for sale:
Thomson elite seatpost - 27.2 x 330mm, black. Good condition. £30 posted. Even comes with its little pouch.
Thomson elite seatpost - 30.9 x 410mm, black. 6 rides old - looks brand new. Also features pouch! £40 posted.
Easton monkeylite carbon XC bars, standard NOT oversize. Lo-rise. 62cm/24.5" good condition. £25 posted
Easton monkeylite carbon XC bars, standard NOT oversize. Lo-rise. 61cm/24" damaged at one end following a crash while commuting. Should probably be cut down further to take the damaged section off. Would be great for a fancy fixie build. Not sure if they should be binned, tbh. £5 posted if you promise not to sue me.
Easton EA 70 FLAT bars. 3 deg backsweep. 49cm/19 1/4" wide. Black. Scuffed and worn, but OK other than that.
Shimano M970 XTR crank arm, non drive side. 175mm. Used, anodising has worn lightly, leaving just the 'R'. (£120 on CRC) £30 posted.
XT M740 'conventional' bottom pull front mech. Good condition. £7 posted.
SAINT bashguard - brand new honeycomb style. 36t max. £25 posted
Shimano disc brake adaptor - IS to 180mm post mount caliper. £7 posted.
Hope ProII conversion kits (All new & unused):
1 x QR £9 posted
1 X QR with 2 spokes - £10 posted
1 x 20mm with 2 spokes £12 posted
Other Hope stuff:
1 x floating rotor for mono mini/M4 160mm. Black floating section 6 bolt. £10 posted. Used lightly.
1 x floating rotor for mono mini/M4 180mm. Black floating section 6 bolt. £10 posted. Used lightly. Will sell as a pair for £15 posted.
Hope mini disc brakes IS mounts (NOT mono mini), inc Goodridge hose upgrades. Used, but in good nick. 160/180mm rotors, plenty of pad life left. £70 for the pair posted.
1 x Hope mini rotor. Brand new in packaging. 160mm 6 bolt. £8 posted
1 x Hope mini rotor. Brand new in packaging. 180mm 6 bolt. £8 posted. Pair posts for £12.
Manitou Mars airsprung 100mm forks. (Circa '03, I think) Feature TPC damping and rebound adjustment. Being totally honest they could do with a service, but when they are, they will be buttery smooth. Post mount. I think I have the v-brake bosses somewhere. Star-fangled nut installed. THink there is about 8" of steerer on there, but would need to check. £35 posted.
Got a couple of frames I am selling too, which I will stick in another post - A Cannondale HT with a lefty and a Marin HT.
Pics available on request of everything above. Mail me via my profile.
John
