I have for sale some Avid Code brakes F&R, they are in good condition and work as they should. Hose length should be long enough for the largest of bikes and they fit my XL Commencal Meta 6 with plenty to spare. I bought these brakes off this forum and they didn't work that well when I received them (even though they were advertised as in good working condition)! So they have been serviced ie, cleaned, re bleed, new pads fitted etc and I have been using them when outing my Mete 6 with no problems, no more than 12 times of use. Cosmetically there are a few marks on the brakes, a little brake fluid corrosion at the expansion ports, polishing on the brake lever from gloves rubbing and a few light scuffs on the calliper body. But I would say they are in good cosmetic condition, as mentioned before the brakes work as they should.
No rotors or adapters come with the brakes!
Looking for £105 posted OVNO or a swap for some other brakes, maybe some Hayes stroker trail in white with good hose length? Don't need any hardware if they are Hayes.
Email for pics or questions.
Cheers.
