I have a brand new disc brake adaptor that allows you to fit the caliper to older frames that do not have the caliper tabs. It is a great bit of kit and i use one on my hardtail cannondale frame with no problems. Can send pics fitted - this one is brand new in the package.
RRP is £30-35 but will post for just £20 as not needed.
Classifieds - For Sale
[closed]
FS: A2Z Disc Brake Frame Adaptor BNIB to retro fit disc brakes to older frames
Posted 2 years ago #
HOw well do you reckon it would with track ends?
might treat the chameleon to a rear disc....
Posted 2 years ago # -
Any bike with flat dropouts it works really well on. Obviously with rear facing tabs depending on where the axle sits it may mean changing the wheel takes slightly longer, but the adaptor can easily be 'adapted' with a file in fact i only need use one of the bolt fixings on mine to get enough compression and once the axle/qr is done up they dont move.
Julian YGM. Pics available as fitted to my hardtail and new mount in packaging if required.
Topic Closed
