rock lobster 853 frame classic design inc easton seatpost £135
the frame has been used and has got a fair few scratches all over it inc chain suck but nothing a respray cant fix
top tube length 22 inches center to center
forks
rigid orange steel forks. v brake mounts on the back. plus disc mount cut ~215mm £35
old school rockshox sid forks. back in the day top of the range but prob now best suited for a commuter or a winter mtb. not sure what the seals are going to be like inside but if anyone is interested.. cut length ~205mm £25
wheels
a set of mavic crossmax sl probably about 5 years old had a fair bit of use but are in pretty good condition quite a few scuffs and scratches but still true. 6 bolt. inc skewers. (Not inc rotors or cassette) £160
shimano hubs possibly deor with mavic 117
not bad weight for what they are.
few scratches from sitting around, have only been ridden for a couple of hours, bearings still fine
6 bolt. inc skewers. £70
brakes
full working pair of avid juicy 3 inc pads never used though have a fair few marks on them from being in a draw. probably need re-bleeding inc pads £45
shimano deor rear brake inc pad £22
hope mini front inc pads £22
raceface ride flat bar 58 cm scratches from taking off a tight shifter £12
raceface ride stem c2c 100mm £12
i live in sheffield if your interested and want to pick anything up
Pete Crawforth
email
shot_gun_pete AT hotmail dot com
