First up two stems;
- Superstar Zephir Pro OS 110mm 5deg - marks from fitting but pretty grand - £25
- 3T Team ARX Team Stem OS 90mm 6deg Ti Bolts - marks from fitting and one scratch as in photo, if you use the stem 'roadie down' it would be on the underside - £30 Bolts in photo aren't the ti ones.
Blackwell Stem - 25.4mm 120mm -20deg - a spot of rust marks on bolts- handy for flat barring a road bike - £10 posted
Prologo Colnago Z5 saddle, only fitting marks on the rails, 5 road rides under the other half only - as this http://www.probikekit.com/uk/colnago-z5-bicycle-saddle.html - £15 posted
Shimano flat bar shifter LH r440 triple (worked fine on a double for me) http://www.chainreactioncycles.com/Models.aspx?ModelID=30139 - couple of cosmetic marks - £10 posted
Mavic Br301 Road wheel skewers, came with 2011 Ksyrium Elites - I've not taken pic's as they are still unopened in their wrappers - £20 posted. But they are as these;
All prices posted 1st class recorded. Offers and all that...
Email in profile, pp gift or BT preferred, but happy to take normal pp if you cover the fees.
Cheers all
