As above, only ridden twice, in excellent condition. Frame only with DHX shock upgrade. Will come with Hope seat clamp and Cane Creek headset.
Frame Specifications
•Accepts 120 - 150mm forks
•5 inches of rear wheel travel
•Made from 7 series Aluminum
•Frame Weight 5.3 lbs without shock (Medium)
•All frames have the bottom bracket and head tube faced, ready for installation.
Product Features
•Custom made hydrofromed, butted top tube and flared manipulated down tube
•Full carbon fiber rear end for weight savings and compliancy
•Anodized 7 series aluminum hardware.
•Center of mass technology for a centrally balanced chassis.
•Proprietary inverted extra wide bottom bracket shell for improved rigidity.
•Race and trail proven geometry refined over a decade.
•Wider diameter high quality Enduro bearings for smooth, durable, and reliable suspension action.
•Bead blasted anodized finish.
•Neutral braking: CHUMBA frames are active under braking forces to ensure excellent traction throughout all terrain during your descent.
•Efficient pedaling: Axle paths and shock rates configured to eliminate pedal bob and squat - ensuring pedaling power hits the ground.
•Minimal chain growth eliminates pedal feedback.
contact:andycraig2000ATyahooDOTcom
