2009 Specialized Stumpjumper S-Works FSR Carbon
Size - Large (19" centre-to-top)
Great all-rounder with top of the range spec. Selling due wanting something new.
Was used as a second bike along so has covered minimal miles. Very well maintained by cytech qualified mechanic. Rear shock serviced around September time, forks serviced early summer time both by Specialized. Original (high) specification retained. Everything works on the bike as it should, it needs nothing other than to be ridden!
Specification:
S-Works FACT 10m Az1 carbon frame lends 120mm of travel with FACT carbon seatstays, M5 alloy chainstays, a carbon drive-side dropout, integrated Brain mount and full cartridge bearing pivots.
The Specialized AFR rear shock is designed with a Trail Tune Inertia valve, Brain Fade and adjustable rebound for the ultimate in terrain-sensing technology.
Roval Controle SL wheelset is race-proven on the World Cup Circuit by Christoph Sauser and Lene Byberg! Sealed bearing hubs with carbon front shell and DT Swiss Aerolite stainless spokes.
Avid Ultimate hydraulic disc brakes with lightweight magnesium lever body and carbon blade, titanium hardware and alloy-backed organic pads provide modulation and control at every speed.
The Specialized Future Shock S120 fork delivers 120mm of air-sprung travel and terrain-sensing technology, including Trail Tune, Brain Fade and rebound adjust. Designed with a lightweight carbon crown and steerer.
Full specification available on Specialized's web site: http://www.specialized.com/gb/gb/bc/SBCProduct.jsp?arc=2009&sid=09SJFSR
Bike will be given a once over by Cytech qualified mechanic before being sold to a new owner. Postage is no problem but I highly recommend meeting up to view the bike so you can give it a once over to make sure you are 100% happy with it. Can meet in or around the Lake District. If postage is required it will be sent extremely well packed in a bike boxed and fully insured.
Priced at £1,750 ono.
Email: Matthew.Freestone@sky.com
RRP of 2012 equivalent model is £7,000!!!
