2008 Specialized Safire comp WSD size medium.The coulour and spec are exactly the same as the 2009 model retailing at £1565 + upgrades mentioned below.The bike has only been used for approx 3 months last year before my wife got pregnant and is in excellent condition,frame was covered in protective tape from new.The only marks are a few stone chips on the cranks.
The shifters, front and rear mech were upgraded to 2008 XT and have only been used for two rides since fitting.Spec as follows apart from the upgrades mentioned above.
£900
If you have any questions etc please contact me martyndavison79@aol.com
SPECIALIZED SAFIRE FSR COMP
2008
FRAME All new Safire FSR M5 manipulated alloy frame w/ Women's specific ORE TT/DT, Designs for Women geometry, sealed cartridge bearing pivots, DMD Direct Mount F. Der, replaceable derailleur hanger, disc only, 120mm travel
REAR SHOCK Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.25x1.75"
FORK Fox Float 120 RL, 120mm travel, rebound/compression adjust, lock out, alloy steerer
HEADSET 1 1/8" threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEM Specialized adjustable rise, 31.8mm clamp, 3D forged w/CNC finish
HANDLEBARS Specialized XC low rise 31.8mm bar, 6066 butted alloy, 6 degree up, 8 degree backsweep, 620mm wide
GRIPS Specialized Womens MTB, dual density
FRONT BRAKE Custom Avid Juicy 5 SL, hydraulic disc, 160mm rotor
REAR BRAKE Custom Avid Juicy 5 SL, hydraulic disc, 160mm rotor
BRAKE LEVERS Custom Avid Juicy 5 SL, hydraulic disc
FRONT DERAILLEUR Shimano M581 LX, DMD, top swing, dual pull
REAR DERAILLEUR SRAM X-9, 9-speed, mid cage
SHIFT LEVERS SRAM X-7, Aluminium 9-speed trigger
CASSETTE Shimano HG-50, 9-speed, 11-34t
CHAIN SRAM PC-971 w/ Power Link
CRANKSET Shimano M542, 2pc custom for Specialized
CHAINRINGS 22S/32A/44A, 4 bolt 104/64mm
BOTTOM BRACKET Shimano M542, 2pc custom for Specialized
PEDALS Crank Brothers Smarty custom for Specialized
RIMS DT Swiss custom for Specialized X420, 24mm w/ eyelets, 28/32h
FRONT HUB Specialized Hi Lo disc, 28h CNC flange and disc mount, sealed cartridge bearing, 9mm DT RWS alloy QR
REAR HUB Shimano custom M525SL hub for Specialized, 32h, alloy QR
SPOKES DT Swiss 1.8mm stainless, alloy nipples
FRONT TYRE S-Works The Captain 26x2.0", 120 TPI, tubeless ready aramid bead, dual compound
REAR TYRE S-Works The Captain 26x2.0", 120 TPI, tubeless ready aramid bead, dual compound
TUBES Specialized Ultralite, .6mm, presta
SADDLE Specialized Women's Ariel MTB, hollow Cr-Mo rails
SEAT POST 2019 butted alloy, two bolt non-setback, 30.9 x 350/400mm
SEAT BINDER Alloy collar w/ QR, 34.9mm clamp ID
WEIGHT 12.3kg / 27lb
NOTES Protective clear coat, derailleur hanger, reflectors, owner's manual
