For sale
2 pairs of Formula Oro k24 Brakes.
I've got on with these really well, but I've decided to trade up after having a feel of some Shimano m785's recently. None of these come with discs or adaptors, but I can provide the original stainless mounting bolts
Set One:
These are the original oros before Formula split the range into k18, k24, puro, bianco, etc... They're specced the same as k24s.
Front & Rear with typical cosmetic wear from use. HEL Braided Stainless and teflon hoses on both. Front hose 850mm, rear hose 1360mm. The front lever assembly is brand new and un-used since I crashed October 2011 and it was replaced (amongst a fair amount of other stuff) on insurance. Seals replaced in the other lever, and both calipers last october – Obviously bled at the same time.
Come with a set of part worn (but mostly there) sintered pads, two unopened pairs of superstar kevlar pads and an unopened set of superstar sintered pads.
£65posted
Set Two:
A more recent pair of Oro K24s. Front & Rear Goodridge hoses on both. Front Hose 810mm, rear Hose Typical cosmetic wear from use. I serviced these in October 2011 at the same time as the other set, replacing seals in the levers and calipers and replacing both master cylinders and bleeding them. This set have the one finger levers, rather than the standard two finger levers.
Come with a set of part worn (but mostly there) kevlar pads, two unopened pairs of superstar kevlar pads and an unopened set of superstar sintered pads.
£65 posted
More pictures of both available.
