I bought this shock new old stock, and it has only been lightly used.
It has had air sleeve servicing VERY regularly, no more than 8-10 riding hours apart, and so there is no sign of wear on the shaft. I have just done the air sleeve service for the next owner, and here are open shaft pictures so you can see the whole shaft without the air can in the way:
It is 165mm eye-to-eye, 1.5" (38mm) stroke, 12.7mm eyelet size.
If the new owner wants I can, at parts cost, replace the eyelet bushings (I have the right tool).
Asking £85
