Viewing 18 posts - 1 through 18 (of 18 total)
  • Frozen freehub?
  • philfive
    anyone else had this? took bike from shed and it didn’t engage and just span. left it out for 15 mins and it was fine again? any way to stop this happening other than keeping it in the house.
    TandemJeremy
    Oil it? I assume its water in teh freehub?
    philfive
    i oil it after every ride.
    iainc
    have had it a few times, usually when freehub approaching end of it’s life !
    philfive
    cheers iain good news indeed 😀
    druidh
    philfive – Member
    Seriously??
    Yes, I bought a second hand DT Swiss singlespeed wheel recently (did I mention I’ve got a singlespeed now ?) and found the freewheel didn’t engage properly for the first half of my commute to work.
    About half a turn of the cranks and a bit of crunching from the hub before it engaged. Once it was in it stayed in, although I didn’t stand up to pedal, just in case.
    Coming home after spending the day in a warm room, it was OK.
    philfive
    well ok then after every weekend, all parts that need lubing get it
    singlespeedstu
    Do you strip the freehub and clean/oil it or just spray a bit of GT85/WD40 on it?
    philfive
    remove the wheels remove the cone? and clean and relube the bearings. probably completely wrong mind.
    philfive
    MidlandTrailquestsGraham – Member
    so do u think squirting GT85 or similar water repellent into the hub may help?
    cynic-al
    OP your pawls are sticking down in the freehub/freewheel body. This is usually because the grease in there has dried out or its corroded in there (i.e. on its way out).
    Usually it’s a bit of effort to get lube in there and if you are getting oil in there that’s BAD as it’s too light and washes the grease out.
    If you can wash out the innards and replace with light grease you may extend its life.
    iainc
    phil – I tried that on mine after drying it out overnight on a radiator. Next ride it froze. I think once the pawl mechanism gets a bit worn it is much more susceptible to freezing as soon as any moisture gets near it. Mine was an XT.
    will1
    This can happen in cold weather the pawls freeze. I had it happen on a night ride once and people say to pi$$ on the freehub – it worked for me.
    philfive
    cheers, i’ll order a new freehub
    Marge
    Shimano seems to be quite sensitive to it.
    My mate has had issues with his XT a few times (cold shed) & my XTR did the same thing at -10deg…
    Probably, as a temporary measure, although I intend to strip and re grease it.
    MarkN
    +1 on what Cynic-Al says. I have had this a couple of times now. A strip clean and rebuild normally brings it back to life fine. If you leave it like I did they pawls will fail IME.
The topic ‘Frozen freehub?’ is closed to new replies.
