I’ve fitted and adjusted front mechs before, it should be a 30 minute job tops but I must have spent 3 1/2 hours trying to adjust a Deore M591 front mech with a Deore shifter and I feel like tearing my hair out (for the record the rear one set up perfectly just as expected).
The front mech. is the right height and parallel to the chainrings and the limit screws are set too. First off if was jumping from the granny ring to the big ring on the first click, then it would work spot on (for no apparent reason). Now it’s shifting up and down the rings correctly but when the chain’s in the middle ring the inner plate of the mech. is rubbing the chain in all gears (which would suggest that the cable tension is way too high, except it’s not and in the other two rings everything seems fine). I’ve tried new cables and I’m starting to wonder whether the shifter is dodgy.
I’m a novice mechanic for sure, but it’s not as if I haven’t successfully fitted mechs. several times before. Any ideas?
I’m going to give it a break and try again tomorrow.
