Viewing 10 posts - 1 through 10 (of 10 total)
  • front mech gear cable routing on Mega TR
  • jimmy
    Just got a mega tr frame and it looks like it has a bolt on mech mount (or maybe it’s just for a chain guide) but no cable guides on the frame. Is this right or can it be done?
    shredder
    It is a mech mount and the guides run on the underside of the top tube.
    Mine came with a choice of double guides for a front mech and dropper or single guides. Also on the back of the seat tube is a mount that accepts a C clip thing to hold the cable coming down to the mech.
    tops5
    Yep should be a bag of guides in the box
    jimmy
    Right, still struggling with this. I don’t see how the c clip thing on the back of the seat tube is of any use. It needs to be an actual cable stop to tension against… Right?
    gt900uk
    Cable stop is built into the direct mount front mech.
    rab5474
    The cable outer will run directly to the front mech
    gt900uk
    rab5474
    Just make sure you have a 2×10 mech. 3×10 will foul the swingarm as the cage is longer
    samjgeorge86
    Don’t run a front mech. Problem solved 😆
    jimmy
    Riiiight, so I do need direct mount. Sorted, ta.
The topic ‘front mech gear cable routing on Mega TR’ is closed to new replies.
